Enabling Arlie
  • May 10, 2026
  • 105 views
Team,
We have commvault On-Prem with version 11.40.6 and planning to enable Arlie.
Please let me know if we need to buy separate license or it included in capacity-based license?
and also, I want to understand the steps to enable Arlie when checked documentation its very highlevel.
Enabling Arlie
  • May 11, 2026
Hi ​@Mentee ,
To enable Arlie AI Assistant in Commvault SP40 using the Command Center, follow below steps:
Prerequisites
Enabling Arlie in Command Center
  1. Open the Command Center.
  2. On the top right corner, click AI assistant.
  3. In the Enable Arlie AI Assistant dialog box, click Yes.
  4. The Arlie chat box will appear on the right side of the screen.
https://documentation.commvault.com/2024e/software/enabling_arlie.html
  • May 11, 2026
Hi Pradeep,
Thank you for the reply.
I dont see any option to enable Arlie in command center on top right corner.
will it gets enable after whitelisting below URLs? or do we have any reg key to enable the same?
Note: Attached is the screenshot for your reference.
Scott Moseman
Forum|alt.badge.img+23
Side topic, you definitely need to upgrade to a newer MR.
Scott
  • June 5, 2026
Hi ​@Mentee
Have you got Arlie enabled after whitelisting or you still have the issue?
