Encrypting Network Traffic over HTTPS in enabled by default?
  • July 3, 2023
  • 481 views
Nikos.Kyrm
Forum|alt.badge.img+16
Hello to all!
I read some similar threads about Encrypting Network Traffic, but Im a little bit confused.
A customer wants to know if the Commvault backup installation (11.28) has by default Network encryption over HTTPS between CS / MAs / clients?
I need to clarify if encryption over network traffic for Commvault Servers are enabled by default, at this point I don’t care about Encrypting backup data.
https://documentation.commvault.com/11.24/expert/134328_enabling_encryption_in_commcell.html
Please for your feedback,
Nikos
Best answer by John Robert
There is some performance degradation when enabling end-to-end encryption compared to unencrypted. but this is primarily due to cpu overhead of encrypting traffic.
Default is still to run unencrypted between the clients/mediaagents/commserve as they are considered to be in a trusted network environment.
Traffic between Mediaagent and Blob is encrypted as long as the blob is configured with https.
https://learn.microsoft.com/en-us/azure/storage/common/storage-require-secure-transfer
in addition you can configure commvault to encrypt data at rest, giving you an additional encryption layer that are not directly controlled by azure.
Onno van den Berg
Forum|alt.badge.img+24
It's been a while since I started a brand new CommCell environment from scratch, but as far as I know it is not enabled by default. You will have to configure network topologies to accomplish this if you want to enable end-to-end encryption for both control and data traffic.
Nikos.Kyrm
  • Community All Star
  • July 4, 2023
Hi @Onno van den Berg
Thanks for your reply.
In case I configure network topologies for end-to-end encryption, Im going to face any performance degradation?
Also, in case you have a Azure Blob Storage as a backup repository, by default the traffic between    MA ↔ Blob Storage   is encrypted over HTTPS?
Thanks again,
Nikos
Forum|alt.badge.img+9
  • July 4, 2023
