Endpoint Protection Modul Trial
  • February 22, 2021
  • 68 views
Forum|alt.badge.img+18
Hi there!
I would like to get familiare with Commvault Endpoint Protection solution, however I am not pretty sure, how to access it.
Is the Commvault Endpoint Protection a part of Backup and Recovery solution? If I download Commvault Complete™ Data Protection trial version, will I be able to test Endpoint Protection as a part of it as well?
Any advice and suggestions will be greatly appreciated!
Best answer by Stuart Painter
Hi @drPhil
We have a couple of options regarding endpoint protection that you might want to take a look at:
https://www.commvault.com/backup-solutions/endpoint-protection
Metallic is our cloud based solution or Commvault Backup & Recovery includes endpoint protection capabilities.
Commvault Backup & Recovery trial should enable to you also trial the endpoint protection solutions in the same package.
Stuart
Hi @drPhil
Stuart
  • Challenger
  • February 23, 2021
Hi @drPhil
Stuart
Hi @Stuart Painter,
you are right. The Endpoint Protection trial is a part of Commvault Backup and Recovery package. Further questions about the Endpoint Protection I will open in a new thread.
Thank you for your contribution.
