EntraID Protected objects
PatrickDijkgraaf
Novice
Hi all,
So I have a customer that has expessed interest in Azue AD (EntraID) backup. According to BoL (https://documentation.commvault.com/2024e/essential/azure_active_directory.html), only the following object types are protected:
  • Users
  • Groups
  • Conditional access policies
  • Enterprise applications
  • App registrations
  • Roles
The customer is aking how to protect other objects, like devices, etc. Microsoft might create new object type at any time, why don’t we just protect all objects?
Best answer by Jon Vengust
Hi Patrick,
Hope you’re doing well.
With our current Entra ID offering, you are correct that we only support the object types from the list referenced in our documentation.
Note, we have limitations in terms of what Graph API supports for backup and the restorability state of the other object types you’re referencing.
Rest assured that we closely track changes to Graph API and the Entra ID platform to expand coverage as capabilities evolve.
Jon Vengust
Hi Patrick,
PatrickDijkgraaf
Novice
Thanks for clarifying!
