Answer
Error after upgrade
  • April 7, 2022
  • 96 views
Hello, I have upgraded from version 11.25 to 11.26 in the normal way.Unfortunately, the system has completely stopped running, when I try to start the Commcell Console it cannot find the javaw.exe file. How to proceed with the repair?
Thank you.
Best answer by Wayn
After various attempts to correct the installation, which always resulted in some error, it helped to run Feature Release 11.25 - Commvault. This detected the incomplete installation and fixed everything successfully.
Thank you.
@Wayn
Ar you starting the Commcell Commcell Console from Start Menu > Commvault?
You can run Setup.exe and select Repair Existing Instance:
Sebastien
  • April 8, 2022
Thank you.
