Error Code: [19:857] When delete offline azure media agent
  • March 6, 2023
  • 136 views
I can't delete an azure cloud mount point and also the library that this mount point is associated with.When I do the deletion, commvault sends me an authorization email, but the deletion is not performed because the library and the month point are offline.The azure cloud service is no longer active, so I can no longer access the mount point folder.
how can I delete the library in this case?
Best answer by Matt Medvedeff
Hi @ECP
Did you approve the deletion in the email? And where are you seeing that the deletion isn’t occurring due to the mount path being offline?
Forum|alt.badge.img+13
Hi @ECP
