Error Code: [24:64] Description: There was nothing to restore - subclient(s) not backed up
  • April 11, 2022
  • 1011 views
I'm getting the error [24:64] Description: There was nothing to restore - subclient(s) not backed up.
When I do the restore of the virtual machine the restore works normally, but when I restore the guest files and folder, the commvault shows this error.
I can also browse the files normally, does anyone have any idea what might be going on? restores are for Nutanix AHV.
Best answer by Mike Struening
@Sdmatos , this is indicating that the type of content you are trying to restore was not backed up based on your configuration.  It sounds like the node or cluster as a whole is getting backed up, but not anything file level.
Here’s the Expert level docs:
https://documentation.commvault.com/11.26/expert/31602_nutanix_acropolis_hypervisor_ahv.html
The Essential docs do say we can restore file level, though I’m not seeing anything detailing the configuration requirements, or restore methods:
https://documentation.commvault.com/11.26/essential/121686_nutanix_ahv.html
Can you confirm how you are backing up the AHV nodes?
