Error Code: [30:325] , SQL backup completed with errors
  • December 29, 2022
  • 940 views
Hi team,
I am facing issue with one of the sql client backup completing with errors,
Description: Error encountered during backup. Error: [Server: The operation was cancelled because of locking conflicts. ]
 CSQLBackup::InitializeAndGetLockForParallelBackupSync(16476): -Warn--: The parallel backup-lock is [LOCKED] for the phase [Full] of database *****
Could someone help on this please?
Forum|alt.badge.img+5
  • December 29, 2022
@Ashok Palani Kumar S
Can you verify if there are any other backups running outside of Commvault against this DB backup?  I would also suggest that you please open up a  Commvault Support Case for further research.
As @Gil S  mentioned check for native backups. If you do not have access to SQL you can see them running in Windows Application log.
Also test a native backup on this database see if that can completes or returns the same error.
