Error SapMAXDB | Backup Medium Not Found
  • August 26, 2022
  • 1218 views
Forum|alt.badge.img+5
Guys,
Sap TEAM is having trouble configuring MAXDb.
I installed the Client on the Server and sent the documentation to SAP Team.
https://documentation.commvault.com/11.26/expert/22215_sap_maxdb_backups.html
But to run the bckup. The error is occurring as shown in the attached imagem.
Are the parameters correct?
Best answer by xor
through the GUI application you can manage the situation better.
The Medium is called “Commvault”.
If you need more information, send me a private message.
I’m backup admin but I sped more time for configurare MaxDB (CLI and by WorkFlow).
Best regards,
Xor
Meera
Forum|alt.badge.img+9
  • August 26, 2022
Hi Carlos,
Do you have the backup medium created as explained in https://documentation.commvault.com/11.26/expert/22205_configuring_multiple_streams_for_backups_and_restores.html
You can check this by connecting using dbmcli and check for medium_getall. If it is not configured , please configure the medium using medium_put as mentioned in the documentation.
Meera
  • August 26, 2022
Thank you @Meera by the answer.
I sent the documentation to the SAP Team to verify the paramenters.
I tried to run backup through commvault,
The backup falied the following message:
Log:
Details:
OK ERR -24927,ERR_TOOLCHK: External backup tool not found The file '/opt/commvault/SapMaxDbAgent/in' already exists.
Meera
  • August 29, 2022
Hi Carlos,
in, out, err files may be created by previous backup attempt. Please remove them with below and retry backup.
rm /opt/commvault/SapMaxDbAgent/in
rm /opt/commvault/SapMaxDbAgent/out
rm /opt/commvault/SapMaxDbAgent/err
  • August 30, 2022
If it helps, use the Database Studio for SAP MaxDB :)
Best regards,
Xor
  • August 30, 2022
Hello @xor
I`m backup analyst, I haven`t knowledge in SAP. How would Studio Database help?
i will forward your answer to SAP Team
  • August 30, 2022
Best regards,
Xor
