Exchange DAG
  • Nov 15, 2024 2:51 AM UTC
  • 12 replies
  • 301 views
we create new client (Exchange DAG) and the discovery works fine. But one of the member servers found was not available. I can select olny of them.
Our AD User accout is correctly configured. Any ideas?
Thank you.
Best answer by fred minig
​@fred minig  as per screenshot one of member node is grey out
following can be reasons
-- host name mismatch
-- missing exchange ida
-- duplicate entries present in GUI of missing member node
--in some case ping from from cs to member server using fqdn and short name both does not work so try that if any issue add hostfile entry (if required)
--check for the MonadCCRProxy.log and EvMGrs.log in Debug 10 during DAG discovery for additional details
-- some case after reconfiguraiton CS GUI needs to be closed open
-- one of the option using resetdag script , to clear any previous association if it is locked (for this we need to reveiw csdb and suggest support case may be helpfull)
Okay, thanks. I'll try
resetdag script,How does it work? Is there a statement
  • Nov 15, 2024 2:54 AM UTC
@Mohamed Ramadan I hope to get your help
  • Nov 15, 2024 3:01 AM UTC
@Divya Trivedi I hope to get your help
Erase4ndReuseMedia
Have you installed the Exchange Agent on that second member server?
If the Exchange Agent were installed, I would have expected the second member server to be selectable.
  • Nov 15, 2024 6:57 AM UTC
The second node already has an agent installed, and the host names of both nodes are FQDN
  • Nov 15, 2024 7:03 AM UTC
Yes, the Exchange Agent has been installed on the second member server
Forum|alt.badge.img+9
  • Nov 15, 2024 7:10 AM UTC
I have checked and found no valid information, and I have checked that the FQDN of the two nodes is no problem, and the ports of CS and CS can also be accessed normally. This problem is caused after CS upgrade
  • Nov 15, 2024 8:38 AM UTC
  • Nov 15, 2024 9:13 AM UTC
  • Nov 18, 2024 1:32 AM UTC
@Sujay kumar wrote resetdag script,How does it work? Is there a statement
Erase4ndReuseMedia
I suggest that you raise this with Commvault Support.
