Exchange mailbox archive "completed with error"
  • June 13, 2022
  • 9 replies
  • 357 views
I’m trying to archive Exchange mailbox but the job is “completed with error”
  • I can browse and recover
  • The messages still exist “As it has been backed up not archived”
  • Check readiness shows that I should add at least one system account “I already added 3 service accounts”
  • Archive & Archive index phases are completed
  • Finalize phase is failed
Check the attachment file for the job logs
Best answer by Mike Struening
That’s an extremely old Maintenance Release (at least a year old).  I would suggest upgrading as the fix in 11.22.28 was likely not included in a pack so low in 11.24.
@Mostafa Amin , we have a few internal articles about this.  Some refer to escalating to development, though another shows an update in 11.22.28.
Can you confirm the version you are on?
  • June 13, 2022
@Mike Struening I’m using version 11.24.3
Forum|alt.badge.img+18
  • July 2, 2022
@Mostafa Amin - Can you please update if the issue has been resolved?
  • July 7, 2022
@Orazan sorry for being late
No, the update didn’t solve it
@Mostafa Amin , if that didn’t resolve the issue, can you open a support case and share the incident number here?
@Mostafa Amin , following up on this one.
Were you able to open a support case and share the incident number here?
@Mostafa Amin , following up on this, though I’m assuming the issue is likely resolved by now.
Marking this as solved, as the update likely resolved the issue.
@Mostafa Amin , please do let us know if this is still an issue, or if you fixed it in another way.
