Export group
  • May 17, 2021
  • 424 views
Is there any way we can export the data we have in the Client Computer Groups from the Java Console   ?  Copy/Paste does not work
It seems that Client Computer Groups aren’t implemented at all in the Command Center ?
Best answer by Sean Crifasi
Hi @Philippe Arnaud,
Thanks for signing up to the community and making your first post!
For client groups in the Command Center, have you checked Command Center > Manage > Server Groups?
Additionally, In the Commcell Console on most windows you can export the view you are looking at. On the right hand side, Click the drop down arrow on the far right of the column headers then save, email or print.
Sean Crifasi
  • May 18, 2021
