Export is not allowed for this media because it is recalled for restore
  • January 18, 2024
  • 277 views
Forum|alt.badge.img+5
By mistake I performed a recall  on a tape media that was already exported, we plan to take it offsite  but still in the library.
The icon is changed
If I try to export it again I have this message.
How to get back to Exported media state before taking the tape offsite.
I just want to get back to the previous state.
Thanks !
Best answer by MichaelCapon
Hello @Amin91 ,
As per the documentation: “the media will remain in the Recall state until you manually right-click the action and select Recall Done. The media will then be marked Available for Export.”
Ref: https://documentation.commvault.com/2023e/expert/recall_media.html
Are you able to try this and confirm back?
Michael
MichaelCapon
  • January 18, 2024
Hello @Amin91 ,
Michael
  • January 18, 2024
Hello @Amin91 ,
Michael
Thanks @MichaelCapon , it perfectly works !
  • February 27, 2026
Hi all,
since I looked at several places for the “Recall done” action → Look in the Commcell Console under “Storage Resources/Vault Tracker/Actions”.
