Failed to get array info
  • Aug 4, 2024 12:05 PM UTC
  • 399 views
Forum|alt.badge.img+2
hello guys,,
i’ve problem when try to run intellisnap backup to Hitachi storage,, the error seems like this below :
fyi, i’ve already configure the storage on array management.. but the erroe messages, tell failed to get array info..
maybe some has experience about it and know how to solve the issues
Hello @Tyo
The script requires an Auth code to run and they are provided by Dev, sorry.
Kind regards.
Albert Williams
Hello @Tyo
I have had a look at some older cases with this error and they go all over the place but there is a chance there is an entry in the CSDB that is stuck and a script provided by Dev is required to clean it up.
if you could raise a support ticket they will be able to do the testing and confirm if this is the issue you are hitting.
Kind regards
Albert Williams
  • Aug 5, 2024 12:38 AM UTC
Helo @Albert Williams
since this is development environment, any chance to do clean it without raise support ticket ?
Kind Regards
Tyo
Hello @Tyo
Kind regards.
Albert Williams
@Tyo I’m struggling with the same issue, just wondering if it got resolved with Support as @Albert Williams recommended?
Thanks for the help guys
Regards
Ivan
