Failed to mount media with barcode
  • January 28, 2024
  • 272 views
Hello
I received this message in the event viewer :
Do you have any ides to solve this issue ?
Thank you!
Chris Hollis
  • January 29, 2024
@ariel_b
If you have access to the support portal website (support.commvault.com), login then access this article:
https://support.commvault.com/Article/Details/64369
If the logs show the same failures in the symptoms section, then attempt the solution steps:
Solution:
Disable the built in sd card reader or cdrom (when applicable) in the BIOS/UEFI (preferable as its harder for it to get enabled again accidently) or in windows device manager (not preferable as could be enabled again more easily)
If using a HP server also see https://support.hpe.com/hpesc/public/docDisplay?docId=emr_na-a00072259en_us
Chris
Hello @ariel_b
Have there been any hardware changes with the library? Has anything been serviced or replaced?
Thank you,
Collin
  • January 30, 2024
Hello @Chris Hollis
thanks for your answer, it is Tape library not sd card , do you have an idea how can I solve this issue?
its library of HP LTO9 .
@Collin Harper  There is no changes in the library .
Thank you!
@ariel_b
Can you check the following:
  1. Verify you are using the Vendor Specific Drivers for drives and Medium Changer instead of generic drivers
  2. Check OS “Messages” log for any SCSI errors (log is found in /var/log)
  3. Check if the OS can see the drives and the Medium Changer with #cat /proc/scsi/scsi
    If the OS does see the drives:
  4. re-scan the SCSI bus with #rescan-scsi-bus.sh -a
  5. Open Expert Storage Configuration within the Java GUI and run a Device Detection
    Device Detection - https://documentation.commvault.com/2023e/expert/expert_storage_configuration_advanced.html#device-detection
Thank you,
Collin
