File system agent is not visible
  • March 11, 2024
  • 14 replies
  • 199 views
I have installed SQL server agent into windows server.
While installing the SQL server agent, File System core and File system are installed automatically.
After the installation, I couldn’t see the File system agent in the client.
All I could see is the SQL server agent.
But if I check the installed software, I can see the File system is installed.
  • March 11, 2024
Can someone tell me, how to make the file system to be visible in the Agent type.
  • March 11, 2024
@kiran if you right click on the client, you should see an option in there to “add or configure the FS agent”
  • March 11, 2024
@Gseibak I don’t see any option like that.
  • March 11, 2024
Here is the screenshot
Hi @kiran ,
What do you see if you release license? Do you see same as below?
Sebastien
SparshGupta
  • March 12, 2024
Hi @kiran
Looks like “File system agent” was not explicitly selected during client install. Hence, it’s not visible.
You can “Create File System Agent” by right clicking on the client → All Tasks → Create File System Agent.
Sparsh
  • March 12, 2024
Hi @SparshGupta I don’t see create file system option in All Tasks.
I have attached the screenshot that I uploaded above.
SparshGupta
  • March 12, 2024
Hi @kiran
Which service pack is this? Do you have a support TR?
  • March 12, 2024
Hi @SparshGupta
I’m in 11.28.107
@kiran ,
You checked Licences as above?
  • March 12, 2024
@Sebastien Merluzzi I have VM backup configured for the server.
When I click on release client, instead of showing the licenses it says that it will prune other agent associated backups.
@kiran ,
That’s strange, it should have opened a box with SQL Server License.
Could it be that you do not have enough Licenses, have you checked?
Otherwise I would recommend you log a case with Support and we will check.
  • March 12, 2024
@Sebastien Merluzzi we do have enough license.
Let me log a case.
@kiran ,
I have the same in my lab, but can see create File System Agent.
Do you have full permissions?
