Force failure on backups not progressing
  • February 22, 2022
  • 1247 views
I found one of my colleagues destroyed one of the server we backed up via File System agent without previously de-configuring it in Commvault. That ended up in a backup job stuck in pending status on “scan” phase during days.
Is there any way to force a backup to be killed if it is stuck in a specific task and it has no progress after some time, possibly without using workflows?
Best answer by Hyder
Woops my bad, I completely skipped over that part! The built in option kills it after 24hrs automatically. In Control Panel → Data → Job Management you can control to some level a global parameter for the behavior.
Hyder
Forum|alt.badge.img+8
  • February 22, 2022
Are you not able to just right click and Kill the job? Eventually, after some retries the job should auto-clear itself too.
  • February 22, 2022
Thanks Hyder,
Obviously I was looking for a method that doesn’t imply human actions but I didn’t specify that, my fault :).
Hyder
  • February 22, 2022
  • February 22, 2022
That looks promising!
