Frequent backup for every 10 mins - Specific folders
  • October 12, 2022
  • 99 views
Hello All,
We have a custom need of performing frequent backup for every 10 mins once to secure some critical information . The jobs are setup and running , but only one job runs per subclient hence only 1 active jobs but a lot of queued jobs in the queue.
Is there a way to handle this or suggestions to overcome the queued jobs ?
Commvault version used is V11.24.60 , where backup are store on HPE apollo Hyperscale X ref architecture.
Best answer by Scott Moseman
You could uncheck this option, if it’s enabled, to stop queueing the jobs.
https://documentation.commvault.com/2022e/expert/6399_job_controller_online_help.html
Scott
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • October 12, 2022
The job is being queued to prevent a failed status, is my interpretation correct that you want to actively backup changed files with a new backup job whilst the previous job is still running?
If this is the case I think you need to validate if 10 minutes is a viable timeframe with your current configuration. How long does a backup generally take currently?
In general you can also change settings to possibly, depending on system resources, shorten time needed for a backup:
  • Allow multiple data readers within a drive or mount point
  • Automatically use optimal number of data readers
https://documentation.commvault.com/11.24/expert/10979_setting_data_readers_for_file_system_agents.html
Or increase network agents from default 2 to 4:
https://documentation.commvault.com/11.24/expert/7124_setting_network_bandwidth_and_network_agents_for_data_protection_operation.html
Dont use the throtteling described on this page btw.
Also keep your resources in check on the client whilst testing a backup with these settings, if you do not have enough resources your application/OS/network connection can have some response issues.
Scott Moseman
Forum|alt.badge.img+23
  • October 12, 2022
Scott
Matthew M. Magbee
Explorer
Scott
This would be my guess. We do this with some logs and such
