generating reports/files with extension .hdr 0kb
  • May 4, 2021
  • 73 views
Forum|alt.badge.img+5
We just updated our environment to 11.23.3 and now the reports scheduled in the adminconsole fail.
If we look in the folder we see all reports ending <report_name>.pdf.hdr or <report_name>.html.hdr and they are all 0kb
If we run reports from the Console GUi reports are generated fine.
We are still investigating, we think connection issue on port 80, but does some knows where the extention .hdr comes from?
kr
Danny
Best answer by Danny
Issue is solved, the webconsole name was changed during the upgrade from 11.22 to 11.23 making it difficult to resolve.
Still have no clue where .hdr stands for
  • May 4, 2021
Hello @Danny,
Would suggest for checking for errors in the webconsole.log. May need to increase the debug level from Commvault Process Manager to get the needed information. I think the hdr file format comes from the conversion process but not sure because you are seeing html output with the same extension.
  • May 7, 2021
