Background:
We have Aux copies moving data to a second location, and from that location Tapes are written. We have 2 Media Agents there, each with 1 mount point to storage (and they share the mount points). The mount points have gotten so large we cannot allocate more space to them (a Windows 256 TB limitation).
We *could* just add more mount points to add more storage but we would like to just “delete the existing mount points” from Commvault, wipe the storage, and then rebuild the mount points so we have maybe 4-5 smaller mount points per server (say 75 TB each). Then we would Aux copy all the data back to that location (which would prob. take 4-7 days).
Questions:
- If we were to do this, would there be any “gotchas” or things to consider (we have a global DDB on this secondary Aux copied location, and several on the primary location)? I assume its not as simple as “turn off aux copies, delete mount points, wipe storage, and then reallocate storage and mount points, share the mount points between the two servers”…or is it?
- We write tapes from this secondary Aux copy location… any considerations for tapes (have to reconfigure something to get them to work again, etc?)
