help with install commserve failover package on pre-deployed commserve .ova
  • February 12, 2025
  • 99 views
Hi guys,
 i just deployed a VMware Image of CV ( 11.36.39) primary and also secondary one for secondary commserve. I wanna configure a livesynce between comserve in my lab. I just log in the primary one as root and dowloaded a commvault_linux_media_11.36.tar and extract it and run a “Install commserver faillover” nothing happen and hangs…
any advices or best-practices  ?
Hi ​@TomasK,
To address the issue with the installation of the CommServe Failover package on your pre-deployed CommServe .ova, please ensure you follow the detailed steps provided in the Commvault documentation. Here are some key points and a link to guide you through the process:
This resource will provide you with detailed instructions and troubleshooting tips -> Installing the CommServe Software for CommServe LiveSync on Linux.
If the installation gets stuck, it is recommended to check the installdbg.log file on the CommServe to identify any issues.
Since the CS is already deployed, you can add the software to the cache and attempt to install the CommServe Failover package using the "Add Software" option in the Command Center.
Dheeraj
