Hotfixes installed
  • June 2, 2021
  • 1554 views
I need to get a full list of installed hotfix of a given client, would someone know how to get it please?
Properties (even advanced) does not shows details, i even don’t find it in reports…
Thanks in advance!
Best answer by Cheyenne Jarvis
Hi @f-red
We go by the Maintenance Release level to identify what fixes would be installed on a client which is why they are no longer individually listed in the CommCell Console. If you need to know specifically which individual hotfixes are installed on a client you can pull this from the CV registry hive on the client machine.
In the registry on the client navigate to: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\CommVault Systems\Galaxy\Instance001\Updates
Nested below Updates are the individual packages installed on the machine which are numbered, and drilling further into each package you can see the fixes that are installed for that package:
You can export the entire Updates key - I found opening it in Word Pad gave the best output to be edited into one list:
Hope this helps!
Cheyenne Jarvis
Forum|alt.badge.img+2
Hi @f-red
Hope this helps!
  • June 3, 2021
Sure it helps, it was what i needed, so thank you!
Have a good day.
