How change Backup Destination using Plans
  • March 16, 2026
  • 91 views
Hi, Can you help me with this real quick?
Commvault 11.32.119.
How can I change the Backup Destination of Plans using Command Center?
Forum|alt.badge.img+2
  • March 16, 2026
Hello ​@Eduardo Braga
The Primary copy and the primary snap copy of a plan are like the default copies of the plan and they cannot be deleted or changed. You can create a new plan and associate the new location as the backup destination.
Scott Moseman
Forum|alt.badge.img+23
I do not recall if it’s possible to promote copies in CC under FR32, and I do not have a FR32 environment readily available to confirm or deny.  I know in FR36+ you can add a new copy and promote it to become the new Primary.  In FR32 you may still need to use Java to replace it.
Scott
  • March 17, 2026
Thanks Scott.
@Eduardo Braga  Please refer to the below article and check if you can promote a secondary copy as a primary copy from the Command center.
If you still want to change the backup destination, please use Java console to make the changes.
https://documentation.commvault.com/2024e/software/promoting_secondary_copy_to_primary_copy.html
Requirements:
  • The secondary copy must be a synchronous copy.
  • You must have the user permissions to create a storage policy copy.
  • To promote a secondary copy that is disabled, enable the secondary copy and then promote it.
  • You cannot promote Air Gap Protect copies, global secondary tape copies, archive copies, and snapshot copies.
