How does backup work for compressed Oracle DBs (Exadata)
  • January 16, 2023
  • 219 views
I would like to know how exactly backups work for compressed Oracle DBs on a Exadata platform.
Does it need to rehydrate the data before sending it to a mediaagent?
If so, is there any specific requirement for that to happen? like extra RAM or extra disk?
Is it the same for non Exadata environments?
Sergio.
Best answer by Gowri Shankar
Hi @Sergio V
Use RMAN compression to Basic  and enable commvault level compression
https://docs.oracle.com/en/cloud/paas/db-backup-cloud/csdbb/configuring-compression-backups.html#:~:text=Recovery%20Manager%20(RMAN)%20supports%20binary,for%20cloud%20backups%20is%20MEDIUM.
For additional information please review the Best practices section https://documentation.commvault.com/2022e/expert/20811_best_practices_for_oracle.html
Forum|alt.badge.img+16
  • January 18, 2023
