How to add DDB partition
  • March 9, 2021
  • 1070 views
Hello All;
I have question about add new partition to DDB. I have CV 11.20.36. I can add to one of GDP (VM, Files, DB) but thi is added to only one of this, not to whole DDB. What is ther propley way to add this partition to DDB?  I can't add the same path to more that one of this partition.
Best Regards;
Pawel
Best answer by dude
You should be able to move a DDB partition from one location to another.
https://documentation.commvault.com/commvault/v11/article?p=12582.htm
Note: If you enabled horizontal scaling (Which you are as per the pic shared) of deduplication databases (DDBs), the software suspends the backup operations and the auxiliary copy operations that use the DDB partition that you are moving. The backup operations and the auxiliary copy operations that use other DDBs of the storage policy copy run as usual.
I would plan a down time, suspend all jobs, get the entire activity completed and resume.
  • March 9, 2021
From 11.22.x we allow using same path. For now create subfolders and use them for adding partition.
  • Certified Expert
  • March 9, 2021
Thank you. Can I use Move Partition after create this partition? In my labs working and I can use same path during Move Partition.
dude
Forum|alt.badge.img+20
  • Community All Star
  • March 9, 2021
