How to change alert threshold over 80%
  • July 28, 2022
  • 737 views
All the alerts concerning Licenses Consumed reaching 80 percent are delivered to me. I would like to change the alert threshold to over 80%.Could you please let me know how to do that?
Best answer by Orazan
Good morning.  If you go into the alerts configuration screen, you will see alert for “License consumed exceeds 80%” line if you scroll down.  Highlight it and hit edit:
Once the configuration window comes up, on the 3rd page you will see the option to increase the threshold.  Make the change here:
Forum|alt.badge.img+18
  • July 28, 2022
Since java is no longer available in 11.34, how do we change this definition on command center?
