How to check in an already installed environment package selections
  • December 26, 2021
  • 904 views
Forum|alt.badge.img+2
How to check in an already installed environment which package selections were used in the initial installation using the Commvault_R80_SP18_20July20.exe installer?
Best answer by Stuart Painter
Hi @Alexandre Oliveira
You can check the packages installed on any client by right click, properties in the Commcell GUI.
This will show the version installed, installation location and the packages installed on the client.
If you want to check what options were provided when the installer was run on a particular client, the install.log file may contain the options selected.
However, only 1 version of the log file will be retained and any new installation/update activity may have overwritten the original installation log messages.
Stuart
Stuart
  • December 29, 2022
How to check which Version was installed, on already installed (Upgraded) environment?
