How to delete old backup data of virtual machine?
  • July 31, 2025
  • 161 views
license details : Commvault Cloud Backup & Recovery Software for Virtual Machines, Per VM
(10-Pack)
Commvault version : 11.36
There are no CommCell console available & only manage by Commvault Command Center(Web Console).
Taking virtual machines backup and want to delete old full backup data & how to reclaim space on disk.
__________________________________
****Only Commvault Command Center****
Commvault All Documents gives step of CommCell Console but how to perform this task from Commvault Command Center.
Forum|alt.badge.img+2
  • July 31, 2025
The Command Center does not offer a direct option to delete completed jobs—it only allows termination of active jobs.
To delete completed jobs, CommCell Console access is required. For this, you’ll need to open a support case with Commvault. They will provide an authorization code to enable CommCell access.
Thank you Orophile!
