How to disable and delete commserve ha?
  • May 25, 2025
  • 47 views
I've set up CommServe HA (live sync) on a backup location. I wish to disable the peer CommServe and remove it from the primary CommServe because the OS (peer site) has been corrupted. Is there a process for doing that?
Forum|alt.badge.img+5
  • May 25, 2025
Hi
first of all u can disable peer from commandcenter
after than if you  want remove all peer
just  uninstall Instance 2 .
thats all.
