How to estimate Front End data size
  • December 2, 2022
  • 1883 views
mateusznitka
Explorer
I would like to know how to find Front End Terabytes size of my backups.
I see there is Chargeback report in Metrics Reporting which could do the job, but it shows nothing (no idea why):
There is no data available for this report. Verify if one or more successful backup jobs were run on any of the registered CommCells.
I tried Backup job summary report, which shows Application Size and I can filter it to only full backups, but some of fulls are backed up twice a week, some once, so result could not be perfect.
Commvault 11.24.72
Mateusz
Best answer by Gseibak
Hi Mateusz,
make sure its enabled to upload that info to metrics from control panel - Private Metrics reporting and General tab
https://documentation.commvault.com/2022e/expert/59919_general_tab_options_in_private_metrics_reporting_dialog_box.html
  • Chargeback: When selected, enables data collection for the Capacity report and he Chargeback report. To disable data collection for these reports, clear this option.
    • Daily: To display the calculated chargeback over a day, select this option.
    • Weekly: To display the calculated chargeback over a week, select this option.
    • Monthly: To display the calculated chargeback over a month, select this option.
  • December 2, 2022
Hi Mateusz,
mateusznitka
Explorer
  • December 8, 2022
HI Gary,
Thanks for reply. I had unchecked Chargeback option in Control Panel indeed. Thanks!
Mateusz
