How to Generate Report for Storage Policy Schedules and Retention in Commvault v11.36.68 (On-Prem)
  • September 14, 2025
  • 156 views
Hi Community,
I’m working with Commvault v11.36.68 (on-prem) and need to generate a report—either through the CommCell Console or Command Center—that shows details for a specific storage policy.
Specifically, I’d like to export:
  • All schedules running under that storage policy
  • The retention period associated with each schedule
The goal is to understand what backups will run in a given week of the month and what their corresponding retention periods will be.
I’ve been unable to find a built-in report or option that provides this information. Has anyone done this before, or is there a way to build such a report?
Thanks in advance for any guidance!
Sureshkumar S
  • September 15, 2025
Hi ​@Chamandeep Singh ,
There is no report which can give both details together
→ To get schedules and clients use below
To get storage policy and retention use below report
https://cloud.commvault.com/webconsole/softwarestore/store.do#!/135/664/28858
If you need some reports customized, you can reach out to accounts team to involve respective team
Sureshkumar S
