How to get backup duration for individual mountpoints?
  • Mar 14, 2024 1:09 PM UTC
  • 44 views
We’ve got several systems that backup a single drive. There are several mount points within that drive.
Is there a way to figure out the backup duration for individual mount points instead of the whole backup job?
I haven^t found any hints in the logs yet.
Best answer by Collin Harper
Hello @igarape
It might be possible to figure out through logging but with multiple streams it would be extremely tedious to comb through the backup logs. The easiest way would be to separate a mount point into its own subclient and backup that subclient.
Thank you,
Collin
Hello @igarape
Thank you,
Collin
  • Mar 15, 2024 9:25 AM UTC
Hello @Collin Harper
Thanks for your reply. Yes, setting up subclients for individual mount points seems to be the easiest way to go.
Kind regards, igarape
