How to resolve "Optimized scan could not process the request for [path]"
  • January 28, 2022
  • 551 views
ZachHeise
Explorer
Forum|alt.badge.img+8
A couple of my Linux file agents are showing events telling me that “Optimized Scan could not process the request for [/home/]. Falling back to regular scan for this volume/path. Possible causes: Optimized Scan Service is down, Optimized Scan does not monitor this volume/path, or the database is inconsistent.”
This may have begun after updating the commserve, mediaagents, and the Linux agents to 11.25.19 a couple days ago.
How can I resolve this? I couldn’t find documentation on this issue. I am not the primary admin for these file servers, I’m just the commvault admin. I examined the FAQ here and I don’t believe that any of these are the issue.
Best answer by Stuart Painter
Hi @ZachHeise
It will depend on what is found in /home, for example if the installation location has been changed to /home, this is not monitored by Optimized scan.
You can change the volumes or manually add locations to monitored volumes:
Manually Adding Volumes to the Monitored Volumes List
The error suggests that something is present in /home that is not monitored, this may be the installation files themselves or something else, filescan.log may reveal more details.
Stuart
Hi @ZachHeise
Stuart
