HPE StoreOnce: Catalyst over SAN. Grid Store possible ?
  • April 16, 2022
  • 321 views
Forum|alt.badge.img+5
Hi there.
Can a StoreOnce Catalyst device be presented to 2 Media agents and shared to leverage load balancing and fault tolerance ?
On all project I have encountered StoreOnce, they were either over LAN or attached to a single media agent.
Also, can we use a Linux Media agent with Catalyst over FC ? Documentation says MA on linux is supported but not very clear on how the device will be “seen” at the OS level and if additional Linux drivers/software are required.
Abdel
Best answer by Jos Meijer
Hi @Abdellatif AITELBACHA
I have not configured it before, but based on HPE's StoreOnce Catalyst FC in Linux info:
https://support.hpe.com/hpesc/public/docDisplay?docId=a00043535en_us&page=mod_SO_FC_client_config_201505121227.html
Combined with the Commvault CLI to add media agents:
https://documentation.commvault.com/11.24/expert/134573_adding_additional_mediaagents_to_existing_hpe_storeonce_library.html
I would say that it should be possible to have a Linux HA Media Agent setup in combination with a StoreOnce Catalyst library over FC.
My guess though is that the add media agent cli xml only adds an IP sharing towards the second media agent and not a direct FC path. Mainly due to the remark in documentation:
"One mount path per library is supported."
Source: https://documentation.commvault.com/11.24/expert/99429_support_for_hpe_storeonce_catalyst_storage.html
If IP sharing is the case, you will still have a single point of failure on one media agent.
But as I said, never configured it.
Looking forward to reactions from others, hopefully with field experience in this specific setup
Jos Meijer
Forum|alt.badge.img+16
  • Community All Star
  • April 17, 2022
