Hyper scale 1.5 upgrade from 7.7 to 7.9
  • February 26, 2022
  • 377 views
Forum|alt.badge.img+5
What will be the best procedure for OS versions upgrade for HyperScale 1.5 from 7.7 to 7.9 Kernel Version 3.10.0-1160.53.1.el7.x86_64.
i have 6 node cluster, can we upgrade rolling upgrade from 7.7 to 7.9 ?
Best answer by R Anwar
Hi @backup
You can follow the steps below
https://documentation.commvault.com/11.24/expert/107348_installing_operating_system_updates_on_existing_nodes.html
  • February 26, 2022
would you please answer anyone
R Anwar
  • February 28, 2022
