any idea on the below error
Best answer by Collin Harper
Hello
It looks like one of the 10Gb NICs is not being detected properly.
You can run “#ethtool <link>” to check the status of the interfaces. Example: #ethtool enp1s0f4u4
If the status comes back “Link Detected: No” or “Speed: NA” then there is an issue detecting the interface.
Could you also check the network switches and cabling to make sure the network level and physical connectivity is there?
Thank you,
Collin
