Hyperscale 1.5 OS upgrade
  • May 17, 2023
  • 594 views
Hi
We want to upgarde Hyperscale 1.5 OS current 7.7 to latest 7.9 and we have follow following URL
Installing Operating System Updates on Existing Nodes (commvault.com)
Initially it failed due to to able to download OS upgrade from Commvault site during creation of remote cache, then we have fixed download and downloaded. Now we running script  “./cvupgradeos.py” and getting following error, how we can make RPM query complete
“Previous software download and rpm query job was not successful. Please ensure that RPM query completes successfully before running OS upgrade”
Best answer by Emils
Hi @Aju
Error indicates that the initial Download Job was not succesful.
I find when you cycle the commvault services on all the nodes and restart the download job sometimes help with this issue, otherwise I recommend raising a support case to help with this..
Download Job is covered in steps 1-3 in https://documentation.commvault.com/v11/expert/157128_installing_operating_system_updates_on_existing_nodes_using_command_line.html
Emils
  • May 17, 2023
Hi @Aju
