HyperScale 1.5 Reference Architecture Upgrade
  • February 28, 2022
  • 208 views
Hi All,
We are running the HyperScale 1.5 Reference Architecture with RHEL on top of HP Apollo 4200 Gen9 servers. Now we planning to upgrade the OS to 7.9 through CV FR upgrade.
I have few quries and would like to hear from people who did the upgrade already.
  1. As per CV, the upgrade takes around 60-90 min. What would be expected duration per node in real world.
  2. Is there any firmware pre-request required for this upgrade?
  3. Does anyone reverted the change successfully ? If yes, how long it takes per node
  4. Do we have any check point to validate the upgradation once completed for first node? instaed waiting till 6th Node upgrade.
Thanks in Advance
Mani
Best answer by R Anwar
Hi @Manikandn
30-40 mins
No
Revert hasn't been required for any upgrade. First a transaction check is run on the rpm's that will be upgraded. If we find any issues, we don't proceed with upgrade until it's fix. Once transaction check is done, there are very minimal chance of upgrade failing mid-way.
For overall status, check the log /var/log/commvault/Log_Files/cvupgradeos.log on the node.
Detailed progress of yum update can be monitored in yum.log and yum.err.log available in <commvault_logs>/hsupgradedbg folder.
R Anwar
  • February 28, 2022
Hi @Manikandn
30-40 mins
No
  • February 28, 2022
Hi Anwar,
Thabks for your response.
Can we run the transaction check well in advance seperately, to validate my environment?
Mani
R Anwar
  • February 28, 2022
Hi @Manikandn
No, that’s ran before the node is upgraded.
