I need a query to find a subclient based on it's content rules and I need your help
  • December 7, 2022
  • 269 views
christopherlecky
Challenger
Forum|alt.badge.img+21
My Problem
I attempting to create virtual machine pseudo client, but in order to do that I need to provide the subclient id, in order to do that I have to find the subclient that the vm would populate to via it’s discovery rules.
My Question to YOU
My question then is there a query or api to find a subclient by it’s content?
I seriously doubt it exists, but if not can you point me to a table that defines subclient content.
Thanks.
Chris.
Best answer by Gseibak
Hi Chris,
there is a report in the store that shows sub-client content  so you may be able to pull that SQL out to gather what you need.
https://cloud.commvault.com/webconsole/softwarestore/#!/135/663/13916
there is also a REST api to preview content on a VSA subclient which may help.
https://api.commvault.com/#0b124d84-b010-404b-b6e0-20584ec3b38a
hope that helps.
  • December 7, 2022
Hi Chris,
hope that helps.
christopherlecky
Challenger
@Gseibak , Thanks. I will take a look at that.
christopherlecky
Challenger
That report had the dataset I needed, thanks.
