i want to Index cache delete
  • October 11, 2022
  • 873 views
indexcache directory almost full
It doesn't clean up to the set value
so i would indexcache delete manually
how can i do?
Best answer by Aplynx
Deleting the index is just going to cause problems, from waiting on index restores or pending\failed jobs due to index errors.
I’d start by running the load balance workflow\report:
https://documentation.commvault.com/2022e/expert/100974_running_index_server_load_balancing_with_load_balance_index_servers_workflow_indexing_version_2_commcell_console.html
Aplynx
  • October 11, 2022
Aplynx
  • October 11, 2022
  • October 13, 2022
@Aplynx
Thank you. I'll test it
