I would like to ask for help regarding the backup data capacity inquiry.
  • March 21, 2022
  • 25 views
Forum|alt.badge.img+2
When checking the capacity of the backup data, I want to check the capacity by filtering the modified date of the file or the date it was created.
(e.g. 2018.01.01 to 2020.12.31)
(When filtering from Browse and restore, the list of files is displayed as set by filtering, but the total capacity is not displayed correctly.)
Does Commvault support this feature?
The version is V11 SP16.
Best answer by Mike Struening
@tmyoo , following up on this one.  I reread your post and think you are asking to see the size of the file backed up within the time frame….are you not seeing the size in the browse list?
The size of the files should show when browsing the content.
Hi @tmyoo , thanks for the post!
Can you clarify what you need?  when you say capacity, are you referring to the size of the backed up file, or the amount of Capacity Licensing the job is utilizing, depending on the time frame?
what’s the end goal you have in mind?
