Increase Timeout Session for Commcell Console
  • June 29, 2022
  • 2840 views
Forum|alt.badge.img+5
just wanna ask if there is a way to increase the timeout session for commcell console?
i know how to do it on command center and webconsole since i found that article but i dont see any for commcell console.
Best answer by Chris Hollis
Hi @Enzou
Hope you’re well.
You can specify modify the default (3 hours) by following these instructions: https://documentation.commvault.com/11.24/expert/8642_disconnecting_idle_gui_connections.html
Hope this helps.
Chris
Chris Hollis
  • June 29, 2022
Hi @Enzou
Hope you’re well.
Hope this helps.
Chris
Onno van den Berg
Forum|alt.badge.img+24
Yes this can be done! Please check Control Panel -> System
  • June 29, 2022
thanks guys!
