Incremental Backup are not working
  • February 8, 2023
  • 20 replies
  • 1034 views
Hi Team,
I have Facing an issue in commvault backup, While taking the incremental backup of an file system server backup is failing  with below error.
Error Code: [7:286]
Description: Failed to backup file that qualified as extents
Current Commvault version  :11.28.24
Please share me any solution for this issue
Note: Manually I can able to take synthetic full backup it will working fine, only issue is incremental backup only
Best answer by SparshGupta
Hi @Adarsh.op
Can you please raise a ticket with customer support?
As a temporary workaround, you can disable extent based backups by adding below additional setting on the client (or all clients in case of cluster node) -
https://documentation.commvault.com/additionalsetting/details?name=%22bEnableFileExtentBackup%22&id=7641
Set it to value 0.
Sparsh
dude
Forum|alt.badge.img+20
  • Community All Star
  • February 8, 2023
Not a lot of information here to really drive the analysis. You could have collected logs and shared.
I would begin with another FULL backup followed by another Incremental and see if the issue continues, it could be a simple corrupt index issue and that could solve the problem.
  • February 8, 2023
Hi Dude,
Thanks for valuable reply,
I have manually try to take the synthetic full backup This is working fine, after that I will initiate the Incremental backup but again its failing. with above mentioned error only.
dude
  • February 8, 2023
Hi Dude,
I did not mean a Synthetic FULL, I meant a regular FULL backup.
  • February 8, 2023
Ok I will try it , and come back to you
Zubair Ahmed Sharief
Hello @Adarsh.op
Is the client having the issue a Linux LVM based server?
  • February 12, 2023
Hia Zubair,
Thanks for your reply,
No this windows server, and is configured as file system backup in commvault.
Hello @Adarsh.op
Was this working before? Is it a new config?
what is different here from the other windows clients?
is there are any special config on the subclient ?
Has a CV client re-install done as a troubleshooting step?
Has the client been re-registered, if possible (delete the client/ backup (if possible), re-register it)
  • April 17, 2023
Hi Zubair,
It was working before now a days only backup going to failed. This is File system cluster windows 2016 servers(2 nodes are present)
is there are any special config on the subclient ? NO
Has the client been re-registered, if possible (delete the client/ backup (if possible), re-register it) its not possible to do right now.
Has a CV client re-install done as a troubleshooting step?NO
SparshGupta
  • April 17, 2023
@Zubair Ahmed Sharief - We should never delete the client & reinstall it. This is not the correct approach.
@Adarsh.op -  No need to run a full backup. Just provide us the job ID where you saw this event, and share FileScan.log & clBackupChild.log from all nodes involved.
File could have been shrinked at a later point, which might have resulted in this event. Next job (incremental) will pickup this file again and back it up.
Do you know the filename & size of the file in question? Is this a static (no new data dumped / file modified when job is running) or dynamic file?
Edit : Just noticed post is 2 months old, is this issue still happening? Does this happen for all jobs?
Sparsh
  • April 18, 2023
Hi Sparsh,
The Issue will come at intermediately I cant able to share the logs becuase this restricte customer site, Could you please share any troubleshooting steps for solve this issue.
Both Incrementala dn full backup are failing with same error
Do you know the filename & size of the file in question? No Is this a static (no new data dumped / file modified when job is running) or dynamic file? New Data is dumped
Error Code:7:286
Description:Failed to backup backup files that qualified as extents.
  • April 18, 2023
Hi Sparsh,
 is this issue still happening?  YES
Does this happen for all jobs? No one singlke job, Tjsi is Windows based file system cluster
SparshGupta
  • April 18, 2023
Hi @Adarsh.op
Set it to value 0.
Sparsh
Onno van den Berg
Forum|alt.badge.img+24
@Adarsh.op have you tried installing the latest maintenance release on one of the affected clients?
Hi @Adarsh.op ,
I found the correct error message so others can search and find this post:
Failed to backup files that qualified as extents
Can you check the free space where JobResults is located and move it if needed?
Sebastien
  • April 19, 2023
Hi Sebastian,
Jobresults having free space is available
  • April 19, 2023
Hi Sparsh,
Can you please raise a ticket with customer support? No
Below you shared link is not opening could you please share again
  • April 19, 2023
Hi Berg,
have you tried installing the latest maintenance release on one of the affected clients? No
Hi @Adarsh.op ,
I see one customer ran a Full Backup which fixed the issue, maybe you can try that then and confirm.
Onno van den Berg
@Adarsh.op Why can't you open a customer support ticket?
Amanda Powell
Hi @Adarsh.op
My team has fixed the issue with the additional settings site, so the link should work now. If you’re still getting errors, try clearing your browser cache and then refresh the page.
