Index Restore problem
  • April 3, 2025
  • 85 views
I am having a problem performing restores, the Index Restore is not completing and no DDB is in maintenance mode
Hello ​@SollyK
Community is a good place to ask general product questions. When it comes to troubleshooting a error specific to your environment support are going to be the best at providing you a solution quickly.
In the future if you do need Communities help please include the following:
Version:
Recent Changes:
Other impacts or symptoms
Details description:
Error logs:
Troubleshooting taken so far
Kind regards
Albert Williams
  • April 3, 2025
Hi Robert
Version: 11.32.35
Recent Changes: What am aware is the Windows  OS Patches
Other impacts or symptoms - This is mostly happening on the Linux Operating system when trying the restore from APi script
Error logs: See attached restore log
Troubleshooting taken so far - initially the Server which is a Media Agent and an Index server went offine when checking from Media Agents, The services were up and running but in Media Agents showed offline. I have checked the DDB all are online, tried several times to get it online until  have to delete or unistall the CV software and reinstall which eventually brought the Media Agent online however the Restore index is still failing and the restore fails.
Hello ​@SollyK
11.32.35 is still supported but my worry is that .35 was released Nov 24th 2023.
I would start by updating and validating the issue is still present. If it is, given all the steps and possible causes a support ticket will be the best way forward.
Kind regards
Albert Williams
