Inquiry on Upgrade of Commvault from v11.32 to v11.36
  • March 26, 2025
  • 180 views
Im planning to upgrade our Commserver from Commvault v11.32 to v11.36.  I was reading the document and it says since v11.36 comes with SQL 2022 you need to manually uninstall the SQL ( which technically means uninstall everything including the Commvault modules etc ) and reinstall . Is there a more seamless and supported way on doing this?  Seems like Commvault has drop the ball in this process. Use to be able to keep existing version etc.
Scott Moseman
Forum|alt.badge.img+23
Where are you seeing this?  You don’t need to uninstall SQL.
Scott
  • March 26, 2025
dude
Forum|alt.badge.img+20
  • Community All Star
  • March 26, 2025
