Install CLI for qlogin
  • September 22, 2025
  • 43 views
Hallo,
I trying to make icinga2  .ps1 script to check the commvault backup status of a client. If i want to install CLI on non commserver which package from repostory do i need to install?
Best answer by Jos Meijer
Qlogin is provided within the base directory, you will need the core file system agent for this, which you can install as restore only if CLI is your only purpose.
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • Challenger
@Jos Meijer Thank you for reply i wil try it out,
