Install Failed with: 'Swap not allowed during OS/Application upgrade/downgrade'
  • Jan 6, 2025 5:43 PM UTC
  • 196 views
In our commcell we had a RHEL client with the name FakeName. That RHEL server has been taken down and rebuilt as a Win2022 server using the same name(FakeName).
We want to keep our backup history for RHEL server so we renamed it in the commcell to FakeName_Linux.
Now when we try to install on the windows server which is now named ‘FakeName’ we see the following error:
10412 2830  01/06 09:46:36 ####### Checking if client [FakeName] meets all the install requirements.
10412 2830  01/06 09:46:36 ####### Client OS id is 210.
10412 2830  01/06 09:46:36 ####### It is Re-Install/Package Addition for existing client [FakeName]
10412 2830  01/06 09:46:37 ####### Apptype upgrade/downgrade from Old OSID [98] to New OS ID [210] is not allowed
10412 2830  01/06 09:46:37 ####### Old OSType [Unix], Old OSSubType [Linux], New OSType [Windows], New OSSubType [Server]
10412 2830  01/06 09:46:37 ####### Apptype Swap not allowed during OS/Application upgrade/downgrade. Please check CommServe log files for more information.
10412 2830  01/06 09:46:37 2846653 Transaction rolled back
10412 2830  01/06 09:46:37 ####### Error level [2] :: Error Code [67109509] :: Error/Warning String [Apptype Swap not allowed during OS/Application upgrade/downgrade. Please check CommServe log files for more information.]
10412 2830  01/06 09:46:37 2846653 Install client/packages [FAILED] for client [FakeName]
            ---------------- R E S U L T  S U M M A R Y --------------
            Client Name          :     FakeName
            Client Host Name     :     FakeName.corp.fakecorp.com
            Operation Type       :     INSTALL_CLIENT
            Error Code           :     67109509
            Error Level          :     SIM_LEVEL_FAILURE
            Error String         :     Apptype Swap not allowed during OS/Application upgrade/downgrade. Please check CommServe log files for more information.
It appears that although the Name and Hostname have been changed to FakeName_Linux - the CS is still seeing this as FakeName. It seems the client identifier is still also showing ‘FakeName’ and not referring to the name change.
How do I clear out the reference in our CS to the old Linux build that no longer exists so I can have the installer see this as a net new install.
Best answer by Pradeep
Hi ​@Ponte_Vedra
Kindly release the license of the old Linux client and proceed with registering the new Windows client using its IP address as the client name. Complete the registration process with this configuration.
Once done we can then rename the new windows client Name from IP to Hostname.
  • Jan 7, 2025 12:44 AM UTC
Hi ​@Ponte_Vedra
  • Jan 7, 2025 1:38 AM UTC
HI Pradeep,
Thanks for your reply and outlining steps needed to accomplish our task. We will follow these directions and report back tomorrow.
  • Jan 7, 2025 5:52 PM UTC
Hi Pradeep,
We released the license and installed with IP address but its still failing with its same error. FileSystem Agent install failing with Apptype Swap not allowed during OS/Application upgrade/downgrade.
I also attempted to run the installer locally - received this prompt(first screenshot) and installer summary(second screenshot)
  • Jan 7, 2025 6:39 PM UTC
Disregard my previous response.
Pradeep - your steps worked correctly. The client did not use the IP address in both fields to launch CV installer. Once I used to IP for NAME/HOSTNAME the install completed and I could then go back and edit NAME to the friendly name required by my client.
Thanks for your assistance.
  • Jan 8, 2025 12:36 AM UTC
Hi ​@Ponte_Vedra
I’m glad to hear that it worked for you!
