Intellisnap for SQL always on
  • April 6, 2023
  • 58 views
we will deploy Microsoft SQL always on on Azure VM, any chance to use Intellisnap to protect SQL always on?
Best answer by Chris Hollis
@xiwen
I can’t see anything official on our documentation that says we do as of FR30, are you in a position to raise a support case so that we can push thru to the appropriate channels and get you an answer?
Chris
Chris Hollis
  • April 6, 2023
@xiwen
Chris
