Is Azure Data Studio Required?
  • Feb 11, 2025 6:43 AM UTC
  • 501 views
Erase4ndReuseMedia
Azure Data Studio is currently installed on all of our CommServe / Standby CommServe instances, likely as part of the SQL Management Studio installation.
While I can see reference to Azure Data Studio within the “Third Party Applications Installed by the Commvault Installer” page, I haven’t found anything to suggest it is actually required. Can it just be uninstalled?
Best answer by Rajendra Gupta
Yes, we do not need it, and removing it is safe.
  • SSMS will continue to function normally after ADS is uninstalled.
  • ADS is a separate tool and does not impact SQL Server or SSMS.
Azure Data Studio was installed automatically as part of SQL Server Management Studio (SSMS) upgrades.
Erase4ndReuseMedia
Thank you ​@Rajendra Gupta
