Isilon: Accessing OneFS web administration interface over a configured SmartConnect service IP address is forbidden.
  • February 14, 2022
  • 616 views
Natalie
Novice
It appears that our Isilon NDMP upgrade has caused an issue with Commvault. Data is still being backed up, however, I am unable to browse the Isilon’s file structure. The following error appears.
Is there a setting in Commvault I can change or do I need to open a ticket?
Best answer by Mike Struening
@Natalie , I’m closing this thread, though if you have time to continue the issue, please respond and I’ll reactive.
Aplynx
  • February 14, 2022
This is probably worth opening a ticket for.
I concur.  I have never seen anything like this at all.
Can you share the case number with me once created so I can follow up accordingly?
@Natalie , I found the case you created, though it looks like it was closed due to no response.
Were you able to resolve this one on your end?
